spare ecu, from what?
Postby leekycelicy » Fri Mar 21, 2014 10:57 pm
I have a spare ecu, it might be from an mr2 engine I have but not sure as a donar st165 was torn apart for parts, how do I tell?
leekycelicy
Re: spare ecu, from what?
Postby fussellbug » Sat Mar 22, 2014 5:00 pm
If you can read the part number on the ECU (xxxxx-xxxxx), it can be cross referenced in the Toyota EPC. You can also try just doing a google search for the part number and on some Toyota parts websites you will find a list of applications the part number was used for.
fussellbug
Images: 36
Postby leekycelicy » Sun Mar 23, 2014 4:22 pm
fussellbug wrote:If you can read the part number on the ECU (xxxxx-xxxxx), it can be cross referenced in the Toyota EPC. You can also try just doing a google search for the part number and on some Toyota parts websites you will find a list of applications the part number was used for.
the one in my st165 says,
89661 20370
175000-0901 12v
10p 18p 24p
the other ecu is slightly smaller and says
89661-20270
175000-0611 12v
10p 18p 24p
the second smaller ecu might be from an mr2 engine as I have an mr2 engine but I cant say if it was from that for sure.
leekycelicy
Postby sinerasis » Sun Mar 23, 2014 5:25 pm
Almighty Google says your first ecu is euro st165, second one is Japanese st165.
Jeff
1989 ST165 Black
sinerasis
Postby leekycelicy » Sun Mar 23, 2014 5:50 pm
sinerasis wrote:Almighty Google says your first ecu is euro st165, second one is Japanese st165.
after a bit og gooleydoodling I got some info that said kinda the same, jdm and the other I could not find but similar number was from the usa.
thanks though, euro clears things up.
anyway I have swapped them over and the idle hunting has stopped, it now runs fine, a little high on the idle but much better, and the boost fuel cut is a little better now, but still not hitting boost.
leekycelicy
