st165 code 11
Re: st165 code 11
Postby ___Scott___ » Thu Nov 12, 2015 11:47 pm
The TVIS is a non-issue. Its purpose is to enhance intake port velocity below about 4300 RPM, but at idle and low RPMs the the port velocity is low anyway.
Keep fixing vacuum leaks. Even small leaks will cause problems like you are seeing. Cracks in your intake pipes are always troublesome so make sure to get those fixed.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
