5-Pin AFM Plug Diagram?
Postby psipwrd » Thu Oct 30, 2014 11:45 am
Every diagram I found with the AFM has 7 pins, mine has 5. I'm trying to wire in the IAT. Anyone have a 5-pin diagram? I'm a little hesitant about going with the wire color codes alone. I noticed a few different colors when repinning my ECU harness...
Thx in advance!
psipwrd
Re: 5-Pin AFM Plug Diagram?
Postby RAMON ALLTRAC » Sun Apr 16, 2017 10:57 pm
Please if you found that could you send me
thanks in advance
RAMON ALLTRAC
Postby alltracman78 » Mon Apr 17, 2017 12:09 am
Homologation wiring uses the same color for the IAT wire. The extra 3 wires on the regular AFM are superfluous.
Check out any gen II diagram and look for the IAT wire, that's the color you want.
To clarify; regular AFM only has 4 wires going to it. Homologation AFM has 5 wires. Both AFMs use the same color wires, in the same spots. The homologation wiring just adds a second ground wire that is spliced into the original ground wire about 8 inches from the AFM.
Postby RAMON ALLTRAC » Sun Jul 16, 2017 4:49 pm
thanks a lot
Best regards
RAMON ALLTRAC
Users browsing this forum: Soup84 and 1 guest
