Cylinder #1,4 are full of gas.. Hydra Nemisis
Postby BayAreaAT® » Wed Jul 08, 2015 10:38 pm
Recently tried to fire up the new built motor. 1200cc precision inj.
Loaded the base map. Crank the motor for about 10 sec and the cylinder gets filled with about .5 cup of gasoline.
Any one have any ideas?? Thanks in advance
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Re: Cylinder #1,4 are full of gas.. Hydra Nemisis
Postby klue » Thu Jul 09, 2015 1:08 am
injector stuck open,
Postby BayAreaAT® » Tue Jul 21, 2015 12:18 am
Turned out the wires +|- are both giving 12v. No ground wires. I need to see what's causing it.
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby RedCelicaTRD » Tue Jul 21, 2015 2:21 am
Weird. I'm at a loss on that one.
Postby BayAreaAT® » Sat Nov 18, 2017 3:10 am
figured out what was the issues with the fuel. Bad wiring ground
Now all my temperature reading are not working..saying -20deg cel. :x :x :x
Anyone.. please
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby ChrisD » Mon Nov 20, 2017 8:24 pm
BayAreaAT® wrote:figured out what was the issues with the fuel. Bad wiring ground
Anyone.. please
Did you dig into your harness a bunch with the Nemesis install, or is it plug and play? First step is to check continuity between the sensor wires and ECU pins, continuity with power and ground is as it should be. Is it just water temp showing that reading? Factory sensor or aftermarket? Other 5V sensors working ok?
1988 ST165
1994 ST205 WRC
ChrisD
Postby BayAreaAT® » Mon Nov 20, 2017 9:40 pm
I figured it out this weekend. The sensors should’ve been Calibrated during the 2.7 update but it was not.
Chris M.
Ford F150
BayArea,California
www.Boost2maxx.com
BayAreaAT®
