Is AFM 22250-74180 from a ST165?
Postby FC Zach » Mon Oct 19, 2015 12:16 pm
I purchased an AFM/airbox assembly from a fellow member that's parting out his '92 to use on my '92. . . The stuff arrived and after checking everything I immediately noticed my AFM model (22250-74180) differed from the received part (22250-74200).
I intended to keep the purchased AFM as a spare but once noticing the difference and looking into it to find I've been using the wrong AFM since I've received the car (Dec. 2012), I will now be using new AFM. . assuming it functions properly.
The big question I have is. . Where does the AFM that is currently on my car (22250-74180) originally come from? ? My guess is a ST165, sound right? Also, is there any downside to using the '180 on my alltrac? If there were any negative affects from using this AFM I would imaging I'd have seen them by now. .
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: Is AFM 22250-74180 from a ST165?
Postby zaluss » Mon Oct 19, 2015 1:39 pm
FC Zach wrote:I purchased an AFM/airbox assembly from a fellow member that's parting out his '92 to use on my '92. . . The stuff arrived and after checking everything I immediately noticed my AFM model (22250-74180) differed from the received part (22250-74200).
22250-74180 is from the FWD ST162 3SGE.
I can't say for sure how it would impact performance in either scenario.
zaluss
Postby FC Zach » Mon Oct 19, 2015 1:45 pm
Holy crap! That's a big difference! Can't wait to install the correct part and see what/if an improvement is made.
FC Zach
Images: 9
Postby underscore » Mon Oct 19, 2015 2:30 pm
The new to you AFM has the right part number for a 185, when you swap it be sure to reset the ECU in case it's learned anything based on the incorrect one.
