205 gearbox speedsensor
Postby Toyota1968 » Fri Dec 04, 2015 7:02 pm
I can see that the st205 speed sensor is a three pin item with instrument earth , ign 12v and signal on the pins ...... Signal pin appears to be the middle pin...... Can anyone tell me which is 12v and which is earth..... Putting sensor in a rally car and want to use Speedo sensor to drive tripmeter
Toyota1968
Re: 205 gearbox speedsensor
Postby Toyota1968 » Sat Dec 05, 2015 1:34 pm
Bump? If no one knows which pin is which perhaps someone could tell me which colour wire is on each pin......
Toyota1968
Postby Overtriped » Sat Sep 03, 2016 3:27 pm
I am also wondering about this sensor, i plan to use it with my new ECU to get a speed reading to enhance the capability of launch control ect. clocking mileage and speed would be a plus,'
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby Toyota1968 » Sun Sep 04, 2016 9:11 am
I did figure this out..... I will post when I find it
Sent from my HTC One M8s using Tapatalk
Toyota1968
