question for Subaru conaisseurs...
Postby camry90 » Sun Dec 20, 2015 3:27 pm
i have thought of using WRX wiring harness so i can use my Cobb AP on my JDM ST185. the harness is cheap and i have the piggy back already. why not? i know the EJ20 has a trigger wheel that i have to adapt to... and what else?
if i go standalone, i will have to rewire anyway plus the cost of a stanalone is pretty high. and no, i wouldn't want to go MS3
your thoughts?
camry90
Re: question for Subaru conaisseurs...
Postby phattyduck » Sun Dec 20, 2015 6:48 pm
The EJ20 has cam and crank triggers, you'll need both - the ECU won't fire the coils or injectors without both signals. Also it is COP (if US model, not earlier JDM). Seems like a long way around to get where you are going... Saving money on the harness, etc. just to have to spend a bunch extra on custom triggers and/or wheels, etc.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby aus jd 2703 » Sun Dec 20, 2015 7:27 pm
Especially since haltech do a patch harness for st185's to ps1000
aus jd 2703
Postby camry90 » Sun Dec 20, 2015 10:37 pm
Oh, i didn't know about the cam sensor. I was planing on installing COP if i were to use AEM ems, so i will need to install some wheel trigger anyway
camry90
Postby aus jd 2703 » Mon Dec 21, 2015 4:52 am
can run sequential cop with stock cam sensor on the haltech.....
aus jd 2703
Postby camry90 » Mon Dec 21, 2015 7:44 pm
thank you. i guess it's time to sell the COBB AP
camry90
