Injector solenoid causing pig rich?
Postby camry90 » Wed Jan 13, 2016 8:22 pm
my engine ran "ok" but one morning, on idle, it would be pig rich, stutter then shuts off. i am suspecting some electronic problem causing it... either that or the MAF got shorted out?
what happened:
drove over deep puddle of water. on the spot, car shuts down and refused to start again. i kept trying for 5 mins and it ran fine. 2 days later, the problem appears
camry90
Re: Injector solenoid causing pig rich?
Postby underscore » Sat Jan 16, 2016 10:28 pm
There's a few things I can think of, but have you checked for any exhaust leaks?
Postby camry90 » Mon Jan 18, 2016 7:19 pm
Yeah i do have an exhaust leak. I'll have to check out where it is
When all this happened, it was -30 degrees C. So i didn't feel like touching the car plus i was fed up with it.
camry90
