Mines sw20 ECU on EU ST185
Postby alex_ » Thu Jan 14, 2016 7:12 am
Hi
I have a problem with my 1990 celica st185 204 ps europ version.
on ebay i purchase this mines ecu
http://www.ebay.com/itm/321186978770?_t ... EBIDX%3AIT
I have it plugged in directly : The motor control light is always on, engine is running and takes no gas on, similar to when the fuel pump was broken :S
The DTS don't rule (fakecodes)
I think the MINES one is a SW20 1 ( JP ) ECU , right ?
I have this compared with the pinouts to the connector and cable colors...
http://gt4.mwp.id.au/Electrical/All%203 ... iagram.png
my own shoud be the ST185 (USA+CND ) pinout ?
The only difference in pinouts is :
Mines : STJ and EGR missing
My Own : ACT and CCO missing
the rest is in line
What am I doing with STJ , EGR , ACT and CCO ?
sorry for my bad english.....thx alex
alex_
Re: Mines sw20 ECU on EU ST185
Postby alex_ » Wed Jan 27, 2016 10:33 am
I am now getting a bit further , I know the exact pinout of two ECUs .
the difference is that MINE'S has this pins, which is missing on my ST185 harness /ECU:
CCO = to Check connector
PS = Power Steering
PSCT=Power Steering ECU
EGW= Exhaust temperature sensor ( whats the different to THG ? )
ABV=
these pins are not available ( yet ) on my Harness / ECU ( Europa ST185)
alex_
Postby underscore » Wed Jan 27, 2016 3:01 pm
I imagine the only pin you might have to connect is the EGW, the rest shouldn't be needed.
Postby alex_ » Thu Jan 28, 2016 9:13 am
this is the pinout now...
Mappe1.pdf
(12.78 KiB) Downloaded 38 times
alex_
