gen 4 ecu codes
gen 4 ecu codes
Postby Rahvin » Sun Jan 08, 2017 10:59 pm
Hey i just did a gen 4 3sgte engine conversion and did the wiring my self. now i want to know if there is a way to check fault codes just by using the wires out of the ecu as i didn't wire in the check connector. can anyone help me with this please.
jdm st185
new zealand
Rahvin
Re: gen 4 ecu codes
Postby alltracman78 » Mon Jan 09, 2017 8:44 pm
Yes, all you need to do is ground one of the wires from the ECU.
Off the top of my head I don't remember exactly which wire on the 4th gen.
Off the top of my head on older ones it can be either Tc, TE, TE1 or TE2.
Re: gen 4 ecu codes
Postby Rahvin » Mon Jan 09, 2017 10:08 pm
cool thank you for that will try it today after work
jdm st185
new zealand
Rahvin
