ST165 fuel pump?
ST165 fuel pump?
Postby JRWperformance » Thu May 18, 2017 5:53 pm
I've done a 4th gen swap on my 165. When I get it in boost, it feels like its falling on its face. Not sure if the ECU is cutting out or if I'm leaning way out when the injectors open up during boost. Is the ST165 fuel pump adequate for a stock Caldina motor?
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Re: ST165 fuel pump?
Postby zaluss » Fri May 19, 2017 5:23 pm
I ran with the stock ST165 fuel pump on my gen3 swap @17.5 psi for a year without issues. AFRs always looked good at WOT and I never ran into any fuel cut issues.
zaluss
Postby JRWperformance » Tue Oct 24, 2017 8:00 am
Thought I would update this question with my experience. I wired up my wideband today to really see what my newly swapped gen 4 was doing AFR-wise. Under heavy loads the motor starts leaning out. By the time I was up to 5500rpm the motor was starting to creep up to a 13.5 to 1. Way too lean for me... Yep, the stock fuel pump is not enough. I'll be changing out the fuel pump for Supra Turbo pump.
So, if any other 165 drivers do the gen 4 swap, it might be a good idea to swap the pump and filter.
88 Celica Alltrac
78 Honda GL1000
JRWperformance
Postby zaluss » Tue Oct 24, 2017 8:10 pm
Good update though I never ran into those lean issues. I also changed it to the Supra Pump :)
zaluss
