Switch to full style
Post a reply
Injectors cut out after 2 seconds
Sun Feb 04, 2018 12:20 pm
Good afternoon,
Recently I swapped my t18 2.0GTI (3sge) with a mr2 3sgte. Because I couldnt use the old harness I changed my old harness to fit the engine.
The problem now is that when I fire it up it only runs for 2 seconds then dies out.
What I tested:
AFM disconnected
B+ to FP on dias (fuel pump works excellent)
Measured Allmost all the wires to the sensors
When I spray starter fluid in the intake it keeps running. So I’m sure it cutts of the injectors grounds.
I read something about that the mr2 has a resistor pack for the injector and the celica hasnt. Could it be that causing my issue? And if it does how can I fix it?
Re: Injectors cut out after 2 seconds
Mon Feb 05, 2018 5:53 pm
Post a reply
