Smart tuner 6
Smart tuner 6
Postby MLracing » Mon Aug 23, 2004 2:59 pm
Hi are any one here using a SMT6??
I got some problem whit the ignition wire, I cant find the right wire on the ECU. Ive tried the Cranksaft signal and the ignition signal.
what do you think guys?
MLracing
Postby alltracman78 » Mon Aug 23, 2004 11:09 pm
What is SMT6?
What problem with ignition wire?
Postby MLracing » Tue Aug 24, 2004 9:19 am
its i fuel and ignition management system
MLracing
Postby MLracing » Thu Aug 26, 2004 10:44 am
what wire on the st165 ecu would you guys use to retard and advance ignition timing??
MLracing
Postby ChrisD » Thu Aug 26, 2004 2:21 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby brophats » Tue Sep 07, 2004 11:01 pm
yeah i'm having the same problem. I obtained a smart tuner 5 and the wiring is identical. I found a wiring diagram from their webpage but it didnt work for me, i couldnt find an rpm signal. if anyone has an oscilloscope if they could find the ignition signal that would be awesome.
Demetrius
Demetrius Patin
1991 st185 RC
Seattle, WA
brophats
Postby MLracing » Sun Sep 12, 2004 2:17 pm
brophats wrote:yeah i'm having the same problem. I obtained a smart tuner 5 and the wiring is identical. I found a wiring diagram from their webpage but it didnt work for me, i couldnt find an rpm signal. if anyone has an oscilloscope if they could find the ignition signal that would be awesome.
Demetrius
yeah that would be great
MLracing
Postby Weasy2k » Wed Nov 03, 2004 8:10 am
Wowsa looking at the difference between my mr2 ecu diagram and this one...alot different :shrug:
Anyway so you take the IGN IN Plug B PIN 2....taht did not work?
it should be the NE+ wire (labeled in any BGB or HAYES electrical diagram)
Whatever wire that is coming from the distrbutor is the one for the IGN this is your crank signal wire and your RPM wire.
I just was refered here by a mr2oc member and i remeber being registered to the old forum long ago :) (see my other thread)
THis is a old thread i know :)
-Johnny
1991 Mr2 Turbo
Sea2Sky Tuning
Perfect Power SMT6/7 Dealer
www.sea2skytuning.com
Weasy2k
