supra injectors part 2
Postby ruffneck » Wed Aug 25, 2004 8:01 am
ok, so I got my 550cc soopra injectors (wicked), just thought I'd ask before the install, do the injectors just push out of the fuel rail?, the chiltons manual doesn't go into too much detail, it just says "remove", also are new insulators and spacers required, or can you just re-use the ones on there...thanks anyone
ruffneck
st185 that's getting there
melb, aust.
ruffneck
Postby Griffin » Wed Aug 25, 2004 3:20 pm
the O-rings and stuff should be replaced, but the injectors themselves can just be pulled out once the retaining plate over the ends has been removed.
For what its worth I found it easier to remove the entire fuel rail and service it off the vehicle.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby Plex » Wed Aug 25, 2004 6:00 pm
Coat the o rings with vaseline so they dont become all brittle and crusty later on, they'll last longer..
..:.Red 1988 ST165 All-Trac Turbo.:..
Plex
Postby ChrisD » Wed Aug 25, 2004 7:27 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby ruffneck » Thu Aug 26, 2004 5:04 am
thanks guys, that's the kind of advice I was looking for....I will be using these with an ems, but just out of curiousity, how would these run on a stock ecu?...mine is a jap import and runs lean as hell, so I'm thinking it mightn't be too bad?
ruffneck
melb, aust.
ruffneck
Postby Griffin » Thu Aug 26, 2004 7:53 am
ruffneck wrote:thanks guys, that's the kind of advice I was looking for....I will be using these with an ems, but just out of curiousity, how would these run on a stock ecu?...mine is a jap import and runs lean as hell, so I'm thinking it mightn't be too bad?
You would be about 25% rich - which is to say it would run like crapola.
Dave Staba
Sealy, TX
Griffin
Postby tweekgt4 » Thu Aug 26, 2004 10:45 pm
i just swapped out my supra 540cc with st205 540cc injectrors.
definitely remove the fuel rail to change injectors. it's a pain in the butt to pull the injectors out of the rail. i had to pull my supra ones out of my own rail and then i had to pull the st205 injectors out of that rail. took me a friggin hour of wiggling, pulling, and twisting...
before you do the swap, be sure to get new injector o-rings and the fuel rail insulators with spacers.
1999 Volvo V70R, Laser Blue
2001 BMW M5, Titanium Silver
http://www.brsf.net
tweekgt4
Postby ruffneck » Fri Aug 27, 2004 6:40 am
just some questions -
doesn't vaseline break down rubber (as in o-rings)?
why did you do that, what is the difference if they are both 540cc?
I got them reco'ed while they are out of the car, so they have new o-rings, any reason not to re-use the spacers and insulators?
thanks again guys...
ruffneck
melb, aust.
ruffneck
Postby Plex » Fri Aug 27, 2004 7:40 am
vaseline wont break down the rubber as far as I know... coat them or dont coat them.. lol your choice..
Plex
Postby tweekgt4 » Fri Aug 27, 2004 2:29 pm
ST205 have 4 spray nozzles while the Supra has 2.
Not recommended if you don't have an EMS or the ST205 ecu to control the ST205 injectors. They spray a LOT more fuel.
http://www.brsf.net
tweekgt4
Postby ruffneck » Sat Aug 28, 2004 8:13 am
yeah I get that bit, but they are both 540cc, shouldn't they both deliver the same amount of fuel?
ruffneck
melb, aust.
ruffneck
Postby RedCelicaTRD » Sat Aug 28, 2004 9:19 am
They both give the same amount of fuel but the st205 injectors will mix better. This will give you a more even burn which is always a good thing.
Postby ruffneck » Sun Aug 29, 2004 7:53 am
aaahhh...thanks
ruffneck
melb, aust.
ruffneck
Postby Wreckless » Sun Aug 29, 2004 6:08 pm
I would highly recommend the use of lithium grease as a lubricant when installing new injectors and o-rings. Fuel should only be used as a lubricant in a pinch. The bottom line here is that its easier to make a trip to NAPA and spend the few bucks on a tube of the proper stuff than it is to rebuild your car after an engine fire. Its worth it for the peace of mind.
Yes, Vaseline will break down rubber, which is why you're not supposed to use vaseline as a lubricant when you're wearing a condom.
As for a more "even burn", you'd be a hell of a lot better off to just send the injectors to RC or somewhere to get flow-matched. As long as you didn't do something silly like extrude hone your intake manifold, the casting roughness provides plenty of turbulence to ensure proper fuel atomization. I think the differences between a 4-nozzle and 2-nozzle injector would be negligable within those circumstances.
1987 Supra Turbo 5-spd Hardtop silver/grey, 7M-GTE, 399rwhp, 428rwtq @ 18psi 91 octane.
1995 Supra SE Hardtop - black/black cloth, OBDII USDM 2JZ-GTE/ V160 Getrag.. single, fuel, cams, blahblahblah.
1990 ST185 - maroon/grey cloth. The ex kept it :(
Wreckless
Postby Plex » Mon Aug 30, 2004 12:54 am
Wreckless wrote:Yes, Vaseline will break down rubber, which is why you're not supposed to use vaseline as a lubricant when you're wearing a condom.
Interesting... never thought of it that way.. a Toyota Tech i know said to use vaseline... weird stuff.. :P
Plex
