Anyone used or heard of these injectors ???
Postby Wraith » Wed Aug 25, 2004 8:27 am
I'm planning on running 1200cc Indy Blue Injectors... Has anyone used or heard of these injectors before... I'm posting this because I know theres alot of over seas people that post on this forum ...
Wraith
Postby Wreckless » Sun Aug 29, 2004 6:15 pm
1200cc would be way too big for you unless you're shooting for over 650-700whp. I've never heard of a company called "indy blue" either.
1987 Supra Turbo 5-spd Hardtop silver/grey, 7M-GTE, 399rwhp, 428rwtq @ 18psi 91 octane.
1995 Supra SE Hardtop - black/black cloth, OBDII USDM 2JZ-GTE/ V160 Getrag.. single, fuel, cams, blahblahblah.
1990 ST185 - maroon/grey cloth. The ex kept it :(
Wreckless
Postby Wraith » Mon Aug 30, 2004 2:50 am
Wreckless wrote:1200cc would be way too big for you unless you're shooting for over 650-700whp. I've never heard of a company called "indy blue" either.
650 to 700 is the goal...
Indy Blue was used in the Indy Cars and are made by Bosch ... But I wanted to know if anyone used them or heard of their quality..
Wraith
Postby Gary » Mon Aug 30, 2004 5:49 am
Wraith wrote:650 to 700 is the goal...
Is this for your Camry? :shock:
93 ST185
Gary
Postby Wraith » Mon Aug 30, 2004 6:01 am
yes sir... GOD willing
Wraith
Postby Terboman » Wed Sep 01, 2004 12:06 am
Wraith,
Damn those are huge injectors (for the street)! :shock:
What kind of EMS are you using to control them? Motec?
Have you considered staged injection? Say....550cc primaries with say...850cc secondaries? A lot of EMS's nowadays can do staged inj. AEM, TEC3, etc. etc.
laters
Lee
2 Alltracs down...none to go.
Yes....I own a G35 now. :D
Terboman
Postby Wraith » Wed Sep 01, 2004 12:36 am
iMpOrT__dUte wrote:Wraith,
laters
na... Stage injectors are too complicated and alot more parameters to control and watch over... And alot more parameters that can go bad on you ...
Wraith
Postby Terboman » Wed Sep 01, 2004 3:55 am
laters
Hmmmm...yes, can't argue there. I know Troy T was running staged inj with his TEC3...he may be able to help you if are still open to it. I can see running 4x1200cc would be simpler to setup.
Is this an all out race car you're building or...does this thing actually need to idle decently lean? I know people who've run 4x850cc and still ran sorta rich at idle.
good luck man,
Lee
Lee
Terboman
Postby Wraith » Wed Sep 01, 2004 4:15 am
laters
good luck man,
Lee
Its going to see some street duties once in a blue moon.. But, as for idle I dont really care much about idle...
Wraith
Postby Wreckless » Wed Sep 01, 2004 5:39 am
To be honest, I've never heard much good about Bosch injectors. I have no personal experience with them, however.
I took a look through your imagestation folder. Seeing that you're not someone to dork around, you might give RC a call, if you can't find a suitable Nippon Denso injector.
RC can find something that would be perfect for almost any application. They now make a custom set of 1200cc injectors specifically for the 2JZ-GTE with the Veilside intake manifold. I'm sure they could find something that would work for you.
Wreckless
Postby Wraith » Wed Sep 01, 2004 7:11 am
Wreckless wrote:To be honest, I've never heard much good about Bosch injectors. I have no personal experience with them, however.
first of all, thank you for your compliments...
second, I dont like RC injectors my experience with them have turn out pretty bad... Me and a few of my friend that used them... Their injectors start puddling at high rpm ( 9500 rpm redline) and high boost ( hopefully 32 to 35psi max boost)...
Wraith
Postby furpo » Fri Sep 17, 2004 3:05 am
i recommend you take a look at www.speedtechnz.com andre is our tuning guru over here. his evo 3 will be run for the first time this labour weekend and an 8sec pass should be on the cards.
he is happy to supply anywhere in the world and has built over a dozen high profile drag cars over here as well as countless curcuit and rally cars.
furpo
