Hey..is the factory setting for the tvis valves (4200rpm) tied in with cam duration?, as in the optimal point for it to open? reason I ask is, the guy who just did my car said that 4200 rpm was the point that the torque started to drop off, and opening the valves there kept the torque curve going..now he didn't know that that is the point that they open on a factory ecu, I told him to open them at about 3700 rpm, but play round with it a bit.. my theory was that since I am running a bigger turbo, more boost, better intercooling, etc you would benefit from allowing this increased flow into the engine sooner...if the switching point is the same though, that would mean that you wouldn't benefit from changing the opening time unless you changed cams?, or what?...maybe I am way off base, or maybe that is just really obvious?
