Gen 3 Ecu on Gen2 harness/motor
Postby 5speedGT4 » Wed Sep 08, 2004 6:20 am
Ive heard a while back this can be done.... im wondering what all is involved... how much rewiring is necissary. And will my stock accessories work (alternator, etc).
I think it would be kinda nice having that, considering my motor is heading in the direction of 205 land to a certain extent.
Robert, i know you talked about this once. Would you care to add input please?
Andrew
ST165<----Sold
5speedGT4
Postby sardgt4 » Tue Sep 14, 2004 7:32 am
I did the 3rd gen ecu swap on my st185. Mine is a 92 so it was easy. I had to rewire about 6 wires or so. You have to get a 3rd gen igniter, 2 air intake temp sensors, 3rd gen map sensor, and a super afc or something to tune the fuel curve. I got 550s but I dont think its a must. I did all this with the intent to switch to a power fc in the future. Hope this helps somewhat.
John 92 st185
sardgt4
Postby Gary » Tue Sep 14, 2004 1:16 pm
sardgt4 wrote:I did the 3rd gen ecu swap on my st185. Mine is a 92 so it was easy. I had to rewire about 6 wires or so. You have to get a 3rd gen igniter, 2 air intake temp sensors, 3rd gen map sensor, and a super afc or something to tune the fuel curve. I got 550s but I dont think its a must. I did all this with the intent to switch to a power fc in the future. Hope this helps somewhat.
John 92 st185
a write-up please. :)
93 ST185
Gary
Postby alltracman78 » Tue Sep 14, 2004 10:47 pm
sardgt4 wrote:. I got 550s but I dont think its a must.
It probably is, considering the ecu is set up to run that size injector. :wink:
Postby sardgt4 » Wed Sep 15, 2004 10:36 am
i'm not sure how to write this up but Ill try my best. For the ecu swap I had a friend in Japan get me a VPC harness and the 3rd gen mr2 ecu for less than $200. That is why I went along with this mod. I did this with the intent to get a power fc and plug and play it down the line. The wiring is not all that difficult if you have a 92-93 st185. I have a 90 BGB and rewired it according to that at first but the car wouldnt start. I later sourced a 93 wiring diagram and it was almost identical to my 92. I used the wired for the egr to wire in the air intake temp sensor on the manifold. As for the AIT sensor on the airbox i used the wires from the afm. I have 550s in my car and yes I believe the 3rd gen came with 550s stock. However, Robert theorized that using the 440s may work with the st185 map sensor. Since the st185 map sensor cuts out at 17psi and the 3rd gen cuts out at 23psi or so. Using the stock map sensor will make the car run richer with on the 3rd gen ecu which in turn can be offset (leaned out) by using the 440s. I went and bought the 3rd gen map sensor (it was $280!!!). I also went along with a GM air intake temp sensor instead of the 3rd gen one since I couldnt source the right part #. I am going to try and use the one off the 5sfe soon. As for now I leaned out the fuel curve alot with the safc and advanced the timing. The fpr is set at 40psi. I belive the car is running rich and retarted timing since I am using the GM AIT sensor. The car is running pretty good right now. I dont plan to anything more till I get the power fc. I hope this helps. One thing I must add is that since my car is not stock results may vary individually from car to car. here is a list of my mods:
50 trim ct26, sard fpr with dual feed fuel rail mod, safc, 3rd gen ecu, ARP everything, JE 87mm pistons, Eagle rods, TT# 1.6mm HG, Sard BOV, 23X12" Griffin FMIC, Apex intake, Topend 3" DP, homemade 3" piping to the rear axle with HKS rear section (2.5"), ACT street clutch, Greddy profec B, Earl's oil cooler and oil filter relocator (mounted but not plumbed yet), etc + other non performance mods.
John So 92 st185
03 g35 coupe
sardgt4
Postby sardgt4 » Wed Sep 15, 2004 10:39 am
One last thing I forgot to mention is that you have to use the 3rd gen ignitor. If you dont the redline will be at 5500 rpms.
John 92 st185
sardgt4
Postby 5speedGT4 » Sun Sep 19, 2004 6:36 pm
interesting
Andrew
ST165<----Sold
5speedGT4
