does anyone know where to find a short throw kit for my 90 all trac? i can't find anything but simple short shifters. i need the whole kit! please? anyone?
i've seen this one before...looks like just the shifter though...? i'm really pondering this one...recommendations, anyone? TWM looks dope...seems well priced, as well....
TWM isn't just a shifter, it comes with spacers and other little junk that raises the whole little shifter platform up to increase the leverage. I have TWM and its really nice, well worth the cost in my opinion.
I'm with Jprine, I have the TWM short shifter and it is very nice. It comes will all the hardware to install it and very good instructions to follow if you aren't very mechanically inclince :wink:
If you are on the budget, 94-99 Celica GT stock shifter rod will bolt on.
It gives a considerable shorter throw compare to 90-91 alltrac shifter.
It can be sorced for less than $20.
You only need the shifter rod and couple of washers to lift the shifter base up. (same trick as TWM)
Do a search on this thing, I posted a pic there.
