CodingParadox
goldfish":3tlhqg2t said:Nice...very nice. Have any of you seen any dyno plots comparing the SB46 with the ATS TD06 on a car with almost the same mods? I've got everything but the turbo and EMS (including full head work with OS valves and stock cams) and I'm debating between the SB46 and the TD06 (most likely with the ATS Rom tune.) I dont really want to spend much more than 4 more grand to finish the engine.
What made you decide between the SB and the ATS TD06?
I'm just looking to finish out the performance on the car with something fun on the street and even more fun on track. I think i can get pretty close to 300whp on the ATS kit - which would be enough for me. Do you have any thoughts on that considering your experience with the SB?
If you want the easy cheap solution go with the TD06 and ROM tune - the SB46 will require an EMS to get the most out of it.
The TD06 is a worse turbo - less max power, but spools the same or slower than the SB46... The kit also isn't nearly as well-made. Also, Kris is a local guy for me so I'd had lots of contact with him before, and during this whole process, all of which has been great.
As long as by "track" you mean "road courses" and not "drag strip" then yeah, the spool is great. For a drag strip, screw it, just get a giant turbo and cams. The reason I got the SB46 is to get the biggest quickest spooling turbo I could.
