Street Brawler 46 Trim Final - 392whp@24psi, w/Exhaust!
Postby Denver_whiteST185 » Wed Mar 15, 2006 5:46 am
sorry i kinda hijacked the thread
Last edited by Denver_whiteST185 on Wed Mar 15, 2006 5:54 am, edited 2 times in total.
^Ted^
went back to the dark side of hondas!!!
(not really, i just own a completely UNmodified 91 civic dx that gets 45+ mpg now)
Denver_whiteST185
Postby Denver_whiteST185 » Wed Mar 15, 2006 5:52 am
___Scott___ wrote:
Maloy wrote:so what is the harmonic dampener for then?
To dampen harmonics :wink:
A little light reading is in order. Start here:
http://www.suprasonic.org/public_html/s ... amper.html
http://dinancars.com/whitepapersFile.asp?ID=5
From here: http://d-series.org/forums/printthread.php?t=7945
a wise old one warned me about using a lightweight pulley on a D16, I didn't listen........
What I get for being bull headed.........
http://www.bettendorf.com/~mrbone/pictu ... mainsx.jpg
Damn, if i would have realized this a week ago, i wouldn't have bought it. oh well, i guess ill just sell it.
^Ted^
Denver_whiteST185
Postby d1alltrac » Wed Mar 15, 2006 7:00 am
you may have missed it before since denver and i kinda jacked your thread :oops:
but have you considered a 3SGE intake cam? i hear its a small upgrade and being a stock toyota cam i would imagine its possible to gain a little with no loss of bottom end....im just speculating though, i have no experience with this.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby ruffneck » Wed Mar 15, 2006 9:32 am
that`s right! but remember that NO FPR can completly close! they lett thru 50-70lh to! so then you just have 205-185 left! (wolfcatz tested this!)
interesting point...just keep a close eye on your a/f ratio I guess..
ruffneck
st185 that's getting there
melb, aust.
ruffneck
Postby Maloy » Thu Mar 16, 2006 2:56 am
That makes sense, makes me wonder who told me a perfectly balanced motor doesnt need a dampener. Thanks for the links.
88 white st165 (stripped down on jack stands)
86 AE86 corolla gt-s coupe
Maloy
Postby eric thompson » Thu Mar 16, 2006 1:10 pm
I think a perfectly balanced motor doesnt need balance shafts, not a harmonic balancer. IMO
ST165-PARTS-RED
ST165-SCCA STU ROADRACING-(RALLISPEC'S ST165)
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby exST165 » Sat Mar 18, 2006 2:24 am
*nice* build! I'm planning on autocrossing my Alltrac so I'm interested in some of your thoughts on intercoolers at that power level. Would a FMIC seriously affect throttle response? Going to a ST205 WTA setup shouldn't have affected the throttle response but there must be a weight penalty for switching from a TMIC, any noticable affect on handling going around the cones?
TIA,
Thomas
exST165
Postby KORacing » Tue Mar 21, 2006 6:22 am
I've been extremely happy with the results we've achieved with David's car. Another thing to keep in mind when looking at David's dyno run is that it was in 3rd gear, and typically, I see 200-300 rpm better spool between 3rd and 4th. The tune I have helped David with is conservative in order to not blow anything up. His open downpipe run shows approximately 150 rpm better spool than through the exhaust, and the power was achieved at almost 2psi less boost (360 front-whp).
For someone who asked, here is a plot of ATS's TD 06 vs. the SB46 on the same car (MR2) both running 18psi on pump gas (built 2.2L EngineLogics stroker, cams, 70mm throttle body, greddy side-mount IC): Image.
Kris/Lilly Osheim
KO Racing, Inc.
www.koracing.net
MR2 Turbo "Loki" -- 11.1 @ 128mph
Hydra Nemesis EMS PnP Exclusive distributor for 3SGTE Celica Alltrac/GT4
Certified Hydra Tuner -- I will travel to tune.
KORacing
Postby KORacing » Tue Mar 21, 2006 6:26 am
Another thing to keep in mind if you are considering the Street Brawler turbo kit is that we have GT series turbos in the works and are pending testing. These would be available as drop ins to your current Street Brawler turbo kit (same DP same adapter) ideally unless their size proves that we need to up the wastegate to a 44mm Tial.
Kris/Lilly Osheim
KO Racing, Inc.
www.koracing.net
KORacing
Postby Simba » Thu Mar 23, 2006 5:05 pm
eric thompson wrote:I think a perfectly balanced motor doesnt need balance shafts, not a harmonic balancer. IMO
You can balance the rotating assembly until the cows come home. You're still going to have critical harmonics at given RPM points, which is what harmonic balancers reduce. Greatly.
Lots of fast, loud things.
Simba
Postby marklar88 » Wed May 31, 2006 11:38 pm
how bad do 264s affect low end power? and is there anything to compensate for this??(sorry, not to hijack your thread just curious b/c I am thinking about putting them in)
88 alltrac: hks exhaust, hks timer, koni struts, intrax lowering springs,
marklar88
Postby CodingParadox » Thu Jun 01, 2006 12:20 am
They destroy lower end power. If you're looking for a drag car or a dyno queen, use 264s. Otherwise, don't.
David - Former owner of multiple Alltracs. Have moved on to yellower fields...
CodingParadox
Postby toayoztan » Thu Jun 01, 2006 2:37 am
CodingParadox wrote:They destroy lower end power. If you're looking for a drag car or a dyno queen, use 264s. Otherwise, don't.
So what's 272 for, super drag?
David, didn't the stock cam setup limit you to only 392hp? I'm just curious, because i'm looking to get around 450.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1993 Alltrac - http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=37466
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby CodingParadox » Thu Jun 01, 2006 3:35 am
Yeah, but that's the flow limit of the head with this turbo. 264s would give me a little more torque around 5500 rpms, but would kill lower end power, and would end up making virtually the same peak horsepower. For significantly more power you'll need a different turbo.
CodingParadox
Postby toayoztan » Thu Jun 01, 2006 4:09 am
CodingParadox wrote:Yeah, but that's the flow limit of the head with this turbo. 264s would give me a little more torque around 5500 rpms, but would kill lower end power, and would end up making virtually the same peak horsepower. For significantly more power you'll need a different turbo.
Hmm..interesting. I'll have to have another talk with James from KORacing. He ensured me 46trim would have gotten me 450. It's a little ways before i buy a turbo kit, but i'm obviously doing my hw now heh.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
