allblackalltrac
Ok so I think I might have an upgraded wastegate on my car. The guy I bought it from didn't mention anything about it when I purchased the turbo from him so I dont know...
When I did the swap and got her running the boost hit 14-15psi! Thats with the stock ECU and a Greddy BCC, no MBC install at that point. I figured with the BCC the turbo was left to make boost naturally given the mods I have...
I install the MBC and crank it up to 17psi - WOW! After a few days I thought to myself that that probablly isn't such a safe figure to be running on a stock HG. I turn it down, but it still boosts at 14-15psi...and I have the screw wound all the way in!
So my question is this, if the wastegate is upgraded to open at 14-15psi even if I set the EBC/MBC to 8psi will the WG override the MBC/EBC setting?
Sorry if this seems confusing...thats cause it is, I read it over and Im confused now too, lol.
