theUNYTEDone
OKAY, so i'm on my quest for 300AWHP...and have quite a good idea how to get there (old school rally master for a stepdad)...heres my current setup (performance mods only)
-3" turbo back exhaust (SSAC DP), N1 muffler
-BayAreaAT FMIC kit, 2.5" piping
-straight intake with HKS mushroom filter
-52 trim CT26 (100-ish miles)
i'm pretty sure that's all, actually...i've got gauges in right now, and need some small time tuning to be done. so far, i was thinking something along the lines of:
-SB kit from KO (or ATS kit) but leaning more towards SB
-256 cams
-adj. cam gears
-upgraded fuel system?
-upgraded ignition components?
along with this will be a rebuilt motor (pistons, H beam rods, etc...)
also, since my motor will be out, a new clutch and flywheel will also be in order.
any input/reactions? any OTHER things i should look into, such as an EMS?
-256 cams
-adj. cam gears
