Ok well i bought this shifter off celica tech and was told it was a 6th gen heres a pic
anyone verify ?
In any case, i took it apart, took out the lever and did the same with my stock assembly and then i swithed the levers. everything seemed simple enough until i went to put it (the old housing with the new lever) back into the car. The new lever is sticking down to far and it bottoming out on the car so i can't put the four nuts back on. I was told this lever was a good swap to shorten throw but it doesn't seem to fit? what the hay?
anyone try this b4? if so do you have pics of it installed? i dunno what i am missing here. :shrug:
anyone verify ?
