Hi, I just installed an straight intake with the two nipples on it, with a catch can and now the car does not idle right; only idles for 2 secs then shuts off. I ran the hoses correctly, there is two outlets coming from the engine, the first one I ran straight to the intake and the one below that, coming from the crank case, I ran to the Catch can then to the other nipple on the intake. Is this correct. Anything else I can check.
Thank you
Thank you
