Looking for Mechanic for alltrac in N.Nevada or Sacramento
lumbercis
What kind of work do you need done? If its just mechanical then there must be someone competent in Sacramento. Ask on the mr2 boards. They may have more Sactown members.
If its tuning, RickyB from mrcontrols.com is in the SF bay area. But worth the drive.
J.
smog7
alltracshoak":8orro809 said:
depending what you're doing. there's a shop open at my house :D
and its only 250 some miles away! one of these days, one of these days we need to have a garage/tech day...
alltracshoak
depending on the oil leaks and the power steering, i can do the water pump and the timing belt. i can do all but just gotta find out where the leak is coming from.
wizzards581
macattack121":kgr5a6i7 said:
have a couple of oil leaks and power steering ,thinking of doing timing belt and water pump quoated 1200 for everything
i replace timing belt and water pump myself. max should be no more then 6hrs to a day of work.
