st185cs rally car
tybrinturbo
my baby
update soon :D
syko says
I WANT YOUR SUSPENSION!!! She sure looks rough and looks to have had much fun as well. What are you plans for her?
Sifu
OMG! What are you doing? You're going to take a super rare Alltrac and make a rally machine out of her?!? GOOD MAN!!!
Your DMS suspension bits look broken. Hence you should give them to me.
Keep us updated... Looks like a lot of fun...
Wedge
Hey Dude! Totally love it! Can't wait to see it in action!
But you know that the 'V' style bars in the main hoop are no longer allowed right? CARS rules say that has to be an 'X' now.
tybrinturbo
yes the X and V its ok for CARS and FIA
- update mxl dash
- wilwood pedal box
- fron brake kit 296mm rotor with alcon 4 piston caliper
- atl fuel cell, 60 liter
90TURBO4WD
:shock:
wow, this car will be killer when you done!
props for building a hell of a rally car! cage looks like it will help stiffen it up alot too!
gt4tified
Looks f'in awesome man! Love the cage....looks very well built. What about engine...are you planning on a full stock RC setup or are you opting for bigger turbo etc?
tybrinturbo
my new brake kit
[http://s271.photobucket.com/albums/jj151/tybrin/?action=edit&current=DSCN2128.jpg]
toyota sienne rotor and alcon caliper, the braket is buit by dms in montreal[/img]
Sifu
tybrinturbo":2g4tqtfp said:
my new brake kit
:wink:
BTW that looks great. May I ask how much that set you back?
WideFNopen
This is going to be a killer rally car.
Just a heads up about the brake line holder bolt on the inside of the rear DMS shocks- I am not sure about on a 185 but on my 165 this bolt rubbed against the wheel well and almost disabled my rear brakes during a rally.The fix was to switch to a rounded off lower profile allen head fastener. I think that my problems could have been exaggerated by weak rear cradle mounts allowing the rear to shift excessively when loaded but it is still something to watch out for.
Best of Luck with the build!
Showkemp
tybrinturbo":3pp2qii4 said:
my new brake kit
As far as I remember Sienna have 5x114.3 stud pattern and Alltracs have 5x100.
Did You bored stud holes on the Sienna rotors to change the PCD?
What is disc diameter? I see that it fits in 15 inch rim with no problem.
