aus jd 2703
look under driving parts and diff cushion
aus jd 2703":1eil59t5 said:look under driving parts and diff cushion
CMS-GT4":o25z7p9r said:~140usd. Marios' solid mount costs about that much, and you can place your order in english. At least it used to. I am not sure what he charges now.
As for the rear keeping up. I felt like the rear solid mount helped. There was a slight bit of slack in he rear, and when I went to the solid mount and stiff rear springs the car launched harder and the rear felt like it was doing more work.
CMS-GT4":3kvku45d said:I am not sure if we are talking about the same part. I do not think welding will help. The issue is The mount is rubber and tears. I am surprised yours is still intact since they normally tear under regular driving. Its the cushion behind the diff with a rubber center that has a plate in the middle that bolts to the diff.
The cheapest solution is to take the mount, if the rubber is not torn, and fill it with poly. It becomes solid, but its still a little more flexible than solid metal.
They used to offer rear poly mounts in the 90s for the gtfours. But the simpler way is just to pour it yourself like they do when they make DIY sold motor mounts.
CMS-GT4":2yqp2x50 said:I see what your doing. That works too. That should be much easier to do than fill it with poly. And you can always take it off if you don't like it.
I guess once you do it, tell us if you can feel any difference. I am curious if your car is so far over the edge, if you can feel super minor changes or if its so sensitive now, you feel any change.
Either way, I bet driving that car is a very lively experience.
CMS-GT4":3ealr1va said:Either way, I bet driving that car is a very lively experience.
CMS-GT4":pml8hkj7 said:Someday, I will. We need to get IllGt4 to come down too.
gtfour77":19a13mv5 said:CMS-GT4":19a13mv5 said:Either way, I bet driving that car is a very lively experience.
You should come down sometime and go for a spin! That's an open invitation with a place to stay if you decide to come down for a weekend...:wink:
CMS-GT4":2lk6m2d0 said:Here is the c-one diff mount.
You might want to keep the invite to PMs. You get get the whole forum showing up at your house.
darthripley":3suo58hp said:In the MR2 we have a TRD 1.5 way clutch type LSD & we put Kaaz LSD 75W90 fluid in it which works just amazing imho.
The LSD was making some noise at first, there wasn't enough fluid in there & you could hear/feel the clutch plates chatter together on sharp turns.
Once we put in the Kaaz fluid it all the chatter & vibration went away & has been flawlessly smooth ever since.
We purchased the Kaaz fluid from 240sxmotoring.com which shipped promptly without any hassle.
I have a couple of quick questions.
1. I have a 2-way TRD LSD on its way - can I just "plop" it into my ST205 rear pumpkin or will there be a problem with the axle stubs?
2. Can you "plop" a ST205 Torsen LSD into a ST185 open diff pumpkin without having to modify anything?
Thanks in advance!
