All right, so its been awhile, i was away with the blue devils over the summer, but that is now long gone.
Sence being back i hae bought only a couple things. such as cheap ebay stuff, 3" dp, manual boost controler and a couple ecu.s
the down pipe was manly for the cat delete so i can use it to smog, and also broke a couple studs.
i had an issue of on 7lbs boosting on avg. night or day, so i hooked up the boost controller, and $20 and it works. im currently running 10-11, watching for knock, watching to see boost spikes, and im very happy, at first it wasnt hooked up right cause the check valve was backwards. so i was seeing 15-20lbs quickly add up as it spooled. fixed that asap.
With that stuff being done, its a lot quicker, and fun, i dont feel like im going to get run over. had a little race tonight and it was a turboed civic that my shopbuilt for this guy, 240 whp, it was a dead even race until full boost for me, i pulled a little.
next is installing the st205 ecu, cant stand the afm system, dyno runs will be done hopefuly this week as my shop just got the system upgraded.
