88st165's alltracs
Postby 88st165 » Tue Jan 13, 2009 2:01 am
Yeah the manifold adapter is made of two pieces of stainless stock water jet cut to the t3 dimensions. He has done this to his car and he knows about the preheat/post-heat to avoid cracking of the welds but yes of course I will keep an eye on it haha. We decided not to make a bolt on adapter because the nuts always back out, cost more money, more weight, cause turbo to hit the oil line, etc. I was thinking about the ats machined adapter if we were to do otherwise but it was $$$$$$.
The downpipe was also done with no cheater bends so we were proud of that. Also utilizes a diffuser to reduce pressure drop which I havent seen featured on any turbo kit d/p available for the 3s.
Dump is open to the atmosphere but you dont even hear it because I run open midpipe. I do still need to add a few inches to it so it extends closer to the ground. I might have to change it a bit and make it angle tighter to the downpipe b/c it might hit the ASI radiator I just got.
The turbo is also water cooled but I currently dont have the water lines hooked up. I needed to get it running asap so we can run the car and gather the information because we only had the testing equipment for a few hours.
Thanks, we are proud of the kit. We didnt cut any corners and the quality is on par (if not better, dare I say lol, than other kits out there) and we did it for less than a 1/3 for the cost. I still have to get it ceramic coated so the packaging will look better even though the funky color the stainless steel turned after a few hours of hard boosting looks pretty cool. I think the coating will make it look more professional plus the obvious benefits.
Red st165 - Garage Queen turned wannabe track rat
White st165 - slapping back together and hoping for the best
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby bloodMoney » Tue Jan 13, 2009 2:36 am
hahaha on Doug's name...
I told you, I'd be the first in line to buy a Dougie turbo... :) The setup looks great though. Congrats on it! Hopefully by the time I come back home, I'll have a different turbo as well...
~Chris
88 ST165 'Patty'
90 ST185 'Ellie'
'96 GT "Abby" ~ RIP 11/17/2013
'96 GT 'vert "Lily" ~ RIP 08/22/2015
'04 LS430 "Alice"
'98 GS400
bloodMoney
Postby 88st165 » Tue Jan 13, 2009 2:37 am
Hey Chris sorry I didnt get back to you, I spaced out on that one. I pmed you about it.
Black st165 - gone
88st165
Images: 2
Re: 88st165's alltracs
Postby 88st165 » Thu Jul 23, 2015 8:57 pm
Figured I would bump my old project thread. I updated the first post to make it more of a summary. I still lurk around the forums every once in a while and throughout the past several years I see there are a decent amount of new owners. I'm glad to see people still have a passion for these cars. Whats even better are the old school owners still around and to see what amazing cars they have developed over the years. I'm proud to be part of this somewhat rare and obscure group. Its all worth it when that one person recognizes you car and car really appreciate its heritage. Unfortunately as an adult and now parent I find the necessity to have space for other items rather than car parts so I will be posting some of the parts I have been hoarding in the for sale section later this year. I will also be looking on here for some random parts to keep my cars on the road like many of us do almost far too often. BTW love all the build threads that have popped up in the last few years. Every time I decide to lurk around I find a new one with great content. Keep it up guys 8)
Black st165 - gone
88st165
Images: 2
Postby GT4times2 » Tue Jul 28, 2015 4:26 pm
Any updated pics of the cars?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby 88st165 » Tue Jul 28, 2015 4:45 pm
Mods: (pretty basic, keep in mind this car was slapped together when I was a broke college student haha)
-original 1g 3sgte
-ct27 (custom slapped together oil lines)
-mr2 bpv
-aussie 3" dp
-APEngineering mp
-open mp currently (had SSAC 3" twin tip, Aussie 3" twin tip, both never really fit right. Currently have another SSAC that I will modify with vband flanges and make to fit)
-devil's own WI
-larger h/e
-ASI rad
-spec stg3 clutch
-spec lw flywheel
-Mario rear subframe bushings
-st205 diff
-SS brake lines
-battery relocation
-FEAL 441 coilovers for 185
-whiteline bushings (anti-lift/caster)
-whiteline F?R swaybars
-whiteline F/R strut bars
-225/45/16 Star spec z2s
I think that's it, aside from some minor stuff here and there. Its been a while. Its currently under construction as you can see from the pic. Last time I ran it (last year) it was loosing 1qt of oil per lap around a 2 mile track. Oil was leaking (some say pouring) at a high rate right behind the crank pulley. I'm hoping that I just blew out the crank seal but I have yet to dig into it since then. My goal is to get it reliable enough to do a few track days a year and I will be a happy camper. Thinking of picking up a 4runner as a tow vehicle in the future but AAA has saved me plenty so far.
Black st165 - gone
88st165
Images: 2
Postby GT4times2 » Tue Jul 28, 2015 5:21 pm
Looking good. Wheels look good too.
Yikes!! 1 Quart/lap? :shock: That's bad.
Plans on rebuilding the engine? Or just resealing?
Who sells FEAL coilovers? I never heard of them (Just did a search on them). How do you like them?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby 88st165 » Wed Jul 29, 2015 5:23 pm
Well I should clarify that the 1qt of oil that was exiting from my engine per lap was coming through the PCV tube and filling a make shift gatorade bottle catch can full each lap. My theory is that the lack of oil baffling was causing the oil to run up the timing belt side. Not sure what to do to remedy this. I was hoping maybe the Moroso oil pan would solve my issues. Perhaps a much better catch can system is in order as well. Oh also stock brakes not very good. I want to run 15" or 16" wheels max because tires are more affordable. Going to step up to 15" r888s once i get the car sorted out. So big brakes are out of the question. I am going to contact Carbotech to make a pad for the 165 calipers or maybe the 185 calipers. I use the carbotech xp12 compound on my SI and they were amazing.
FEAL coilovers are sold by a well known guy named Odi. When I was searching for coilovers a couple years back I wanted something different from the BC/Ksport/Megan/D2 choices. I contacted other companies like AME, Fortune auto, etc. No one was willing to make a 165 or even 185 application. Odi at FEAL was more than willing to make an alltrac application and even had a decent turn around time. Very professional and knowledgeable guy. I was supposed to do a review on them but I have not had a chance to post it. These feel great on the track and I am comparing them to my SI which has a ground control/koni sport type setup. I love konis so much I wanted to run them on my red celica for the track but I wanted more of a complete system vs a put together type, just my preference this time around. I am very satisfied on how they feel on the street and track.
http://www.rallyracingsuspension.com/page16.php
Black st165 - gone
88st165
Images: 2
Postby 88st165 » Wed Jul 29, 2015 7:00 pm
More on the oil leak. The crank seal is still leaking really bad so maybe it was a combination of both blow by and the crank seal. Whenever I move my car it leaves a nice trail of oil and a large puddle where it sits. I need to seek the advice of those who successfully tracked their cars and hear what they have done to avoid these issues. Alwayzsidwayz is one whom I remember did a lot of lapping days with his 165, though he appears to not be active anymore.
Black st165 - gone
88st165
Images: 2
Postby 88st165 » Sun Aug 02, 2015 3:42 am
You can see my support rig on the left of my car.... ha jk my support vehicle is my buddy's tacoma seen behind my car. Some of these hobbyist type weekend racers have some serious setups.
Anyway did some searching and found these threads. Wish I would have found them before I attempted to beat the crap out of my car on the track. I admit now that I was a bit foolish to think it would have been ok. Its still a 27yr old car, albeit with only 50k, that has never seen that type of abuse before. You live and you learn. Everything else was fine so I will focus my efforts on engine reliability. Even if I only make 250hp Ill still have a blast.
So I've been thinking about my engine issue every since last year. I am torn between just doing a reseal on my original 165 engine (and hoping thats all that is wrong) or doing a st215 swap. I do not know much about the st215 engine in regards to "racing" (track days) durability. Does it suffer from the same oil baffling issues as the 165/185 motors? I dont know much about what has been improved upon on those motors specifically in regards to the oil system/pan.
If my original engine isn't hurt then I would at the very least buy the moroso oil pan and 1.3 bar rad cap. Maybe even evans coolant once I refresh the coolant system.
Good info:
http://www.alltrac.net/phpBB2/viewtopic.php?p=250505#250505
http://www.alltrac.net/phpBB2/viewtopic.php?f=4&t=36270&start=15
Black st165 - gone
88st165
Images: 2
Postby UtahSleeper » Sun Aug 02, 2015 5:12 am
I would say if the motor is not toast, reseal and do all the cheap shit. Get the most you can out of that block.
The st215 is a nice, modern engine. Coil on plug and a better ECU should make it a worth update....
UtahSleeper
Postby 88st165 » Mon Aug 03, 2015 5:36 pm
UtahSleeper wrote:I would say if the motor is not toast, reseal and do all the cheap shit. Get the most you can out of that block.
A reseal is what I would prefer as well since it is potentially the cheapest and easiest option. I do really want to go with the 215 engine from all the good things that people who have done the swap (mr2 and alltrac) have said. My main fears for going straight for the 215 swap was that I will end up with the same oil issues on the track as the 165 engine. I personally don't know of anyone who has done the 215 swap and goes to the track.
Black st165 - gone
88st165
Images: 2
Postby GT4times2 » Mon Aug 03, 2015 6:30 pm
Both valid points. The ST215 is a very nice set up. Coil on plug, side feed intake manifold, less wiring, strong block, fast spooling turbo, decent after market and the list goes on.
However, I see where going for a simple reseal/rebuild would be a quicker way to get back on the road/track. Look into the oil pan upgrade, larger coolers, radiator, water/methanol injection kit, etc to make it more reliable on the track.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby 88st165 » Tue Aug 04, 2015 4:02 pm
Ultimately that is what I am hoping for. I have AAA plus so I got towed 98 miles from the track to back to the city of Chicago where I had my apartment at the time. From there I drove the car, leak and all, 15 miles off boost to where it is stored (was a very slow drive). Had to stop every mile maybe to fill up on oil most of which was at some pretty sketchy gas stations in Chicago . It drove normal aside from the leaking but it was smoking a bit (nothing crazy) which made me think there could be some potential for more labor intensive repairs. I'll have to do a comp and leak down test when I get a chance, new borns take up ALL of your time haha.
Black st165 - gone
88st165
Images: 2
Postby 88st165 » Fri Aug 07, 2015 4:04 pm
Oh yea forgot to mention I did an ice racing event in WI with my pristine 56k mi rust free chassis last year :doh: . Not really sure what motivated me to do that but since my white 165 was not currently running so I took the red one. Don't think I'll be doing that again with the red car. Hit an ice berm a bit and bend in the pass fender at the bottom, broke the side marker trim piece, and damaged the paint on my front bumper. Wasn't really that bad and I got over it fairly quickly. I'm blaming the fact that I had a broken hand during the event which slowed down my steering inputs lol :P . Honestly I don't mind minor damage as long as it was during a driving event and not just tooling around. Its battle damage so I'm ok with that. Next time though I'll take the white car and stud my tires. Regular snow tires just didn't cut it.
Black st165 - gone
88st165
Images: 2
