Turbo Lean
This is for those who want a little more security for their alltrac. This mod will bypass the hatch key hole lock so no one can break in through the hatch.
No tools are needed and this should take about 2-5 min to complete.
The pics can be a bit confusing so use them in comparison with your car. After your finished, the trunk will only open with the release lever inside the car.
1. remove the plastic panel covering the latch.
It should look something like this. You can now see the latch and the key lock. In this mod, we are removing the short cable.
2. Remove the latch end of the short cable.
3. Now remove the key lock side of the cable.
At this point you should be able to remove the short cable. It should look like this.
4. Now there should only be one cable left and it should be on the key lock. Remove that end from the key lock.
5. and now just put the end of the cable you just removed and just install it on to the latch.
Finished. It should now look like this!
