James,
Glad you're coming down. You'l have to give me a ride in the VR-4. I've always like those cars as well.
My AT started making a ticking sound above the valve cover on the passenger side. It only does it when I free rev it when standing still and sounds like a lifter. You can't hear it inside the car but with the hood up, hit the throttle cable and sure enough. Oil level looked good, scan tool shows no knock, no trouble codes...
Also the new Torsen I put in seems to be spraying/leaking around the pinion seal or prop shaft. It's weird because it's not wet at where the seal would be but there's gear oil on the crossmember and on the underbody. I wiped it off, drove around and it came back. So wtf ever..... Maybe I installed the propshaft wrong.
Sooooooo hopefully mine will make it for the whole cruise.....lol
If it blows up, I'm sending it to ATS for a 3rd gen swap.
Keri,
I'm sending u a 2nd version of the map. Apparently when I saved it to my maps it removed the routes destinations to driving points.
Lastly, this same weekend is the Big ROT harley rally in Austin, Robbie Knievel is jumping 12 trucks Friday night, the city is going to be packed and driving roads full of motorcycles.
Keri,
