you could run methanol, use less injector, eliminate the staged injector setup, and run cooler temps and make more power.
from what i've gathered, with that much injector and the power levels you are hoping to achieve, any gas will not combust fast enough. you are going to have to find an alternative.
you really need to look into this. i don't see you getting much past the 1000 hp mark before you have serious egt issues.
