So i ordered a 10mm triple square bit (12 point) from sears ahead of time because the BGB called for it to remove the head bolts. Assumed i could just remove my head bolts . wrong . It was too small. The 12mm bit i just got (also from sears) fits right and i'm removing the head tomorrow.
My question: did toyota later produce a 12mm version of these head bolts? or are these likely some sort of aftermarket bolts? or did the BGB pull a fast one on me? :shoots:
Thanks!
Thanks!
