Hi all!
Checking out Landon's super-awesome setup in the wheel thread got me thinking: what would it take to fit a 10" wide rim on a widebody st185?
viewtopic.php?f=8&t=1327&start=525
From that thread, Landon's specs were 18x9.5 et35 w/25mm spacer in the rear on 255's. So an effective ET of +10 in the rear.
Some additional info from the very first post of the wheel thread back in '04:
TEST DATA
What we know fits on the front:
17x9 +30
What we know fits on the rear:
17x10 +5 (sticks out slightly but has 12.5mm of clearance on the inside)
The max we've seen on the rear so far is 130mm on the inside and 120mm on the outside.
This means a 10 inch wide wheel should fit with an ideal offset of +10 or +12.
So obviously we are talking coilovers and rolled/cut fenders at a minimum. Obviously the rear could handle a 10" no problem, but how much fender pulling would be necessary to squeeze a 10" on the front? What's the minimum safe clearance on the inside? Is it commonly the rim that tries to touch the suspension, or the tire?
To forstall any OT chatter, I'm not asking whether this is a good idea, or whether you would do it. There's no good performance reason to go that wide. It would strictly be for appearance or just to say you did it. That's why I posted in the Exterior forum, and not the Handling forum.
Thoughts?
J.
TEST DATA
17x9 +30
Thoughts?
J.
