[Toyota Part Numbers]
Postby alltrac.net » Sun Aug 08, 2004 4:25 pm
Post common part numbers we need to know about. Your post will be deleted once the part numbers are added to the complete list.
alltrac.net
Site Admin
Postby mofoparrot » Mon Aug 09, 2004 12:47 am
oil cooler water line gasket - 16258-88383
gasket, joint for turbo oil pipe - 15526-88381
Hose from Hell #1 - 16283-88381
#2 - 16282-88380
Exhaust manifold gaskets - 17173-88381
Turbo oil line gasket - 15471-88580
For oil cooler I have
15517-88380
96732-19019
90301-52002
15785-35010
15471-88580
1990 ST185 sold
West Hartford, CT
mofoparrot
Postby Gary » Mon Aug 09, 2004 4:06 am
RC/CS Hood part numbers
Bonnet Panel (hood) 1 53301-20400
Guide #1 1 76182-20020
Guide #2 1 76191-20900
Retainer 2 76188-20010
Bulge (Scoop insert) 1 76181-20901
Plate 1 76192-20010
Cushion 1 76186-20010
Cushion 7 76183-12030
Retaining Nut 6 90179-05081
Retaining Nut 4 90179-05103
Hood Scoop Bolt 3 90164-50033
Retaining Washer 3 90183-06009
Scoop to hood bolt 8 90109-06241
Cushion 8 90540-06032
Retaining Nut 8 90179-06007
Ornament 033=LH, 034=RH 2 75033-20020-202 (Black)
You do not have the required permissions to view the files attached to this post.
93 ST185
Gary
Postby Gary » Mon Aug 09, 2004 4:07 am
RC/CS Bumper part numbers
Reinforcement #1 52021-20210
Reinforcement #2 52029-20010
Fascia 52119-20929
Grille LH 53104-20030
Grille RH 53103-20030
Grille Lower 53102-20030
Grille Center 53101-20450
93 ST185
Gary
Turbo intake hose
Postby HoleShot » Wed Nov 03, 2004 7:14 pm
The first rubber intake hose that connects to the turbo.
(ST185)
#17882-74160 *Hose, A
Black 1992 St185 (98,XXX miles). Stock for now
HoleShot
Postby johnnyknoxvillej » Tue Feb 08, 2005 3:19 pm
10/89-9/93
cam:90311-35040
crank:90080-31022
rear:90080-31073
88 St165
89 240sx
91 240sx conv.
johnnyknoxvillej
Postby johnnyknoxvillej » Tue Feb 08, 2005 7:23 pm
Also oil filter changed numbers, they are made in the phillipines and not the good ol us of a:
st165 old=08922-02011 new=90915-YZZD1
st185 old=90915-YZZA1 new=90915-YZZE2
fuel filters
st165=23300-79105
st185=23300-19225
air filters
st165+185=17801-74020-83
88 St165
89 240sx
91 240sx conv.
johnnyknoxvillej
Postby CodingParadox » Wed Feb 16, 2005 10:16 pm
I've copied all these part numbers down to the TracFAQ. If anyone has more part numbers to add, you should add them to the TracFAQ.
TracFAQ Part Numbers List
David - Former owner of multiple Alltracs. Have moved on to yellower fields...
CodingParadox
Postby RedCelicaTRD » Thu Feb 17, 2005 6:39 pm
I think that rc bumper reinforcement number two is the wrong number. It shows up as a regular celica upper bumper support.
Wayne
1990 All Trac
2017 SRT Challenger Hellcat
Grumpy Moderator
RedCelicaTRD
Postby Gary » Thu Feb 17, 2005 6:46 pm
RedCelicaTRD wrote:I think that rc bumper reinforcement number two is the wrong number. It shows up as a regular celica upper bumper support.
Or is it because they are the same part? :shrug:
93 ST185
Gary
Postby RedCelicaTRD » Thu Feb 17, 2005 11:43 pm
If you use the stock reinfocement the top of the bumper hangs down to low and looks like butt. If i remember on the old board someone had the true part number.
Wayne
1990 All Trac
Grumpy Moderator
RedCelicaTRD
Postby Austen_gt4 » Tue Mar 01, 2005 12:28 am
gas tank related
filler neck-77201-20420
gasket ^ - 77169-14010
evap line- 77018-20130
gasket ^ -77179-16010
valve cover gasket -11214-88381 inner
-11213-88381 outer
engine gasket set-0411174170
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby CodingParadox » Tue Mar 01, 2005 3:20 am
All added to TracFAQ :)
Keep the part numbers coming, people. Preferably adding them to TracFAQ yourselves. ;-)
CodingParadox
Postby InitialD93 » Tue Mar 01, 2005 3:27 am
wrong Reinforcement #2, part number: 52029-20010. This part is identical to the one that is already on your car. I have no idea why they even have it listed.
The actual part you need is 52029-20020
Dustin
1990 All Trac w/ RC bumper, converted to 93
^^^ Old project about to start a new life ^^^
InitialD93
Postby Austen_gt4 » Tue Mar 01, 2005 11:57 pm
ok here are the brake/ gas lines from front to back (185)
tube to fuel tank 77261-20330
tube fuel return 77255-20540
tube fuel main 77251-20670
tube rr brake #1, 47321-20320
tube rr brake #2, 47322-20450
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
Austen_gt4
Return to FAQ / Archive
