project st205 engine swap.
sonochevelle
removed the bumper and mounted the heat exchanger with some garage door opener hanger/straps to the bumper support.
with bumper off
with bumper on
krogers128
where did you get the manifold gasket? i didn't replace mine when i had it off, but i could probably use a new one anyways... i'm doing the same swap but in an st165.
sonochevelle
i got it from a dealer. they said it was the only one in the U.S. but idk how accurate that is.
krogers128
whats the reason for the heat exchanger? thogught about getting one on before for my st205 swap. as well as a new radiator..
sonochevelle
its for the intercooler i didnt get one when i purchased my engine plus its kindof an upgrade from the factory one
sonochevelle
krogers128":2r3y6mmn said:
oh i see so yours didnt come with the top mount, makes sense lol
the intercooler is still mounted on top
its a water to air intercooler. the hot compressed air is cooled by water, and the heated water is pumped to the heat exchanger to be cooled by air
sonochevelle
today was very eventful! lol
i drilled and tapped the coolant housing for the 3rd coolant temp sensor.
routed the wiring harness.
remounted the heat exchanger b/c i didnt like how low it would be to the ground, i did this by notching out the bumper support from the backside with a plasma cutter and welded in supports.
installed the intake manifold
installed berk downpipe.
installed 2" lowering springs on front struts (didnt feel like taking apart the rear suspension yet..)
installed new WIX fuel filter
swapped the fitting on the power steering pump
and i ordered new front cv shafts.
sonochevelle
ENGINE IS IN THE CAR!!!
it went in WAY smoother than it came out.
installed S.S. aluminum cross member mounts
connected the exhaust
connected the wiring harness and ran it through the firewall
intalled S.S. braided clutch line
installed S.S. brass shifter bushings
(the custom short shifter feels amazing and will be even better once there are actually fluids in it.)
installed new c/v axles and put the front suspension back together
installed radiator and hoses
still need to:
make the oil lines to the oil cooler that i fu*cked up during the engine removal :oops:
install water to air ic, mount the ic pump/wire it, run the lines.
relocate the battery and make the battery cables. +add lots of ground straps
fabricate a strait intake pipe and fab. up a "cold air box"
install the rear lowering springs (still waiting for the crash bolts)
swap the fuel pump pin and the fc circuit open relay on the engine harness
put bumper and hood back on
put interior back together
add fluids
pray to the toyota gods that she starts with no problems.
sonochevelle
i need to swap it because the 22 pin connector is inside the car still and i couldn't swap the pin over yet. i dont really care about the resistor yet i just want to make sure i get the car running. im already kind of nervous about it.
sMARTINside
Ok, it was just to send the FPR pin on the right connector. I thought you meant to run the pump full power all the time. :doh:
sonochevelle
HOME MADE SHIFT BOOT SON!!
i was tired of waiting on my mom to make the thing so i went to her place, took apart the old one and made the patterns of the pieces roughly about 2' shorter.
i put the patterns on black suede and cut them out. i decided to use red stitching just cuz it looked cool and i feel that it turned out awesome! the lines arent perfectly strait but o well...
lemme know what u think!
sonochevelle
been getting a lot of little things done..
rear lowering springs in with camber bolts all in
front brakes put back in
ran the battery cable from the engine bay to the trunk (still need to solder the cable ends on)
mounted the intercooler water pump and ran the wires (still need to mount the relay)
siphoned out the 2+ year old fuel
fabricated the 205 coil bracket to the 185 coil mount
shortened the throttle cable bracket (so the throttle plate would close)
now for the fun stuff.
since the the front crossmember (the one that runs perpendicular to the car) was already off i decided to take it to my uncle to have it notched for a bigger exhaust i plan to be fabricating some day.
to start with
we marked the holes on the table by spraying paint over the holes.
we cut out approximately 8 inches out of the crossmember where the exhaust ran over, to be sure i would have plenty of room for the future exhaust.
we then welded 2.5 inch angle iron (about 1/4 thick) to each peice which lowered the lowest point about 1.5 inch from where it was. and making sure they were level with each other.
we used his piranha ironworker (extremely handy machine)to cut a piece of plate to fill the gap between each piece of angle iron. we welded the plate to the angle iron
i dont have the rest of the pics yet but i will upload them tomorrow
i will be smoothing the welds and throwing on a coat of paint.
im almost positive that this setup will allow me to be able to run a 4 inch exhaust if i ever wanted
tjdouble07
Yeah you should have no problems. This is what I did (pretty much the same thing it looks like...):
sonochevelle
Finished up the crossmember today!
bolted it up and it fits great!
i also got the ecm mounted.
coolant lines for the I.C. heat exchanger finished
wired the relay for the I.C. water pump
made a mount for the under hood relay box using garage door hanger and painted it black.(also mounted I.C. wtr. pump relay on it)
dont feel like i got that much stuff done, but it was all very time consuming.. :(
