Ok thanks. That makes more sense. So I will reserve this for my low power things, like code 54 ground and mechanical gauge light bulbs
Speaking of code 54, I have been taking the whole circuit apart and trying to figure out why it is not working.
I started testing things, since one thing that never happened was the lightbulb never came on.
So I tested my bulbs, and all work. Then I tested my relays and they work. So I hooked things back together and I noticed that the INT wire from the ecu is not working as it maybe should. When I replace INT with a ground the relay works. So I need to figure out what INT needs to do in this equation and I might resolve the issue.
EDIT: I just looked at the 205 BGB and between the oem relay and INT is EA1, which I is earth/ground. I think I run a ground between these it will solve the problem with the relay.
I also ran across this page that I will go thru and see if there are any hints.
http://chlichtmannegger.at/dmcvxa.php?q=st205-code-54
