No Problem....it will be easier to ship if you dont button it up, box up the gear assembly & case separately....original case would make it easier to assemble (no shimming needed), but not necessary, as long as the end used knows how.vip09":63aj6vjq said:Thanks for taking a look Pat.
I'll get this put back together soon and have it up for sale since I no longer have an Alltrac.
Lets put this to rest....the single MR2 Diff. will not fit into a (2)/Diff awd Diff....ccsouls":63aj6vjq said:While you have that thing apart, you ought to see if you can get an MR2 LSD on it.
Martin says it can't be done, but Quaife says it can.
You could make history (and a lot of us happy) if you find a way.
alltrac101":1emvqkyp said:Lets put this to rest....the single MR2 Diff. will not fit into a (2)/Diff awd Diff....
ccsouls":fjukak30 said:alltrac101":fjukak30 said:Lets put this to rest....the single MR2 Diff. will not fit into a (2)/Diff awd Diff....
:bangshead:
