aus jd 2703
for kicks i hopped under the car with some calipers and found the front sway bar is 27mm thick and the rear is 20-21mm thick so apart from adjustment there is no gain from another sway bar. maybe get a custom from 25mm swaybar but im really not that keen.
still now change in job status so car is staying a dd.
