aus jd 2703":2vkyy5y2 said:I would assume with the 205 hard inter cooler water pipes you would have to drain the inter cooler and disconnect it. On my 185 conversion I just un bolt it and move it as I use heater hose for the water lines.
Meurz":38c5mcb9 said:You don't need to drain it, just undo the bolts holding it onto the engine and tilt it over to the right when standing in front of the car. It's a closed system with flexi hoses so there is a fair bit of movement possible to access the plugs.
