Minnesota91alltrac
Just thought if anyone has done this and has pics it would be an awesome thread
LegacyofDan":39murn9a said:http://cgi.ebay.com/ebaymotors/Toyota-CT20-CT26-MAJOR-TURBO-TURBOCHARGER-REBUILD-USA_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ33742QQihZ021QQitemZ310129658075QQtcZphoto
and u cant do a turbo rebuild on your own. unless you have the proper balancing tools.
88st165":24cpy0fv said:Its super easy to seperate the center from the turbine housing if you heat the joint with a torch, heat gun, even a hair dryer.
