Boiling after a hard drive is normal with the CT series turbos, they are designed to boil coolant in them to help them cool faster after shutdown. Listen carefully, its the CHRA thats making all those "gurgly" noises..
As for boost, go and get yourself a decent MBC... It seems strange that you wouldnt be boosting to stock levels... if your wastegate controller isnt seeing boost reference at all, or if there is a leak then you would be seeing high boost pressures. If your wastegate is seeing full manifold pressure that is not bled off by a boost controller, then you will be seeing stockish boost levels (7-9psi)
If you are seeing under 7psi of boost then something is wrong... either with your wastegate controller spring, your turbo, or you have a massive boost leak, or your timing is way off.
Remember, if your motor is otherwise healthy and you blow a wastegate controller line, then your boost will go WAAAY up, not the opposite...
Get your motor healthy before trying to up your boost...
