Before.
Now.
1988 toyota celica alltrac. JDM engine and low mileage turbo. SPEC stage 2 clutch,walbro 255lph fuel pump, AEM dry flow filter and custom 3" straight intake, 3" ausie DP, upgraded HE and heat wrapped ST165 WTA IC, 8mm magnacore wires, speedsorce solid motor mounts, ASI Aluminum RAD, 2micron second oil filter kit, prosport EGT-BOOST-WB O2 gauges, all new: seals/gaskets/belts/hoses/ Water Pump/ Timing belt kit, Rebuilt half shafts, new drive shaft u-joints, new control bushings, cleaned and balanced injectors,
