Continuing
Front view of bumper ducting. The idea is that the large hole will take air straight to my airbox. The smaller hole will take air to flow over the trans cooler but what doesnt go through the cooler will be available to the airbox.
See that triangular hole next to the cooler? It goes into the airbox. With the inner guard in place the air will have access to the airbox.
Looking into the airbox from above. At the bottom of the picture you can see the triangular hole and to the left is a larger hole that I cut into the inner guard to allow more access for the spilled air. Oh and where does the air that has gone through the cooler go?
