alltracman78":2n5vtfvq said:A normal alignment should be the same, the rear is identical to the ST185, and the front toe is adjusted the same.
The problem would be if the front camber was off, you can't adjust it with the lower strut bolts [not normally adjusted in a car], but I'm sure there's a way.
