Green_Machtoy2
Building an ST205 out of my AT200
____________________________________________________________________________________________________
Engine Stock 3SGTE
Upgraded Clutch and Flywheel
Clutch- Exedy Hyper Multi Twin Plate Clutch
http://www.nengun.com/exedy/hyper-metal ... ate-clutch
Flywheel- TRD lightweight
http://www.trdparts.jp/english/parts_flywheel.html
Turbo
Stock Turbo
Turbo CT20B @ 11.9-16.9 psi (Depending on tune)
Brakes
Stock
Brakes ST205 Discs and Calipers
Exhaust
Upgraded Exhaust System
Exhaust System Blitz Nur Spec- R:
http://www.nengun.com/blitz/nur-spec-r-exhaust-system
Suspension
Stock Suspension
Suspension McPherson Struts
http://autostyle-usa.com/?pkey=item_inf ... r_url=st20
Intake
Upgraded Intake
Performance Intake MR2 TURBO Performance Intake
http://www.emspowered.com/storefront/in ... 2a6c78c73b
Wheels
Upgraded Wheels
Wheels O.Z. Superturismo (Black)
http://www.tirerack.com/wheels/WheelClo ... sort=Brand
I would like some advice on the parts that I've listed above. Has anyone seen, heard, or experienced anything overwhelmingly terrible with any of the parts that I've linked above. Also regarding the McPherson Struts, how well do they perform compared to a more up to date suspension system? Is this still one of the best systems for the Celica? Regarding the turbo, is there a turbo that is consistently more reliable than the CT20B? One that will give the same performance factor but with more reliability, if it exists what is it? Any advice on the parts above would be greatly appreciated, thanks in advance.
Regards,
Green_Machtoy2
Engine Stock 3SGTE
Turbo
Stock Turbo
Brakes
Stock
Exhaust
Suspension
Stock Suspension
Intake
Upgraded Intake
Wheels
Upgraded Wheels
Regards,
Green_Machtoy2
