Right now I have a set of 17s Scion tC wheels wrapped in some decent rubber @ 215 width and 45 profile. They rub a little bit but i'm about to put on a set of K-Sport Kontrol coilovers and hopefully that will solve any rubbing issue now and in the future. I think the only reason it rubs anyways is because it drives like a boat and bounces way too much since the suspension is shot.
I also drive a 2013 Hyundai Genesis Base with 18in OEM wheels. the tire widths are pretty high... up to 245 width. i was wondering if these wheels with the K-Sport Coilovers will cause them to rub?
I know the bolt pattern is different too. do you guys recommend this bolt pattern adapter?
http://www.motorcitybolton.com/wheel-ad ... pters.html
