So I'm looking for either 20 or 25mm wheel spacers in the rear.
I'll be running 17x9 35+ with 255/40.
I have brand new stock OEM wheel studs.
There's two brands, Ichiba and H&R that seem to be reputable.
On either of those, it seems I would need to run the setup that bolt to the stock hub and has its own studs pressed into the spacer.
Several questions:
1) Overall, which do you recommend, ichiba or h&r?
2) Should I even consider running this style stud, or should I put in extended ARP studs?
3) If ARP extended studs, what's the part # you've found to work?
4) To confirm, our center bore is 54.1?
Honestly, I don't want to pull the knuckle/hub apart all over again just to put in extended ARP wheel studs, unless i'm convincned it's absolutely necessary/safer to do because the other setup is a "for-sure" crap deal. I didn't think I'd be needing or using them so I went with OEM new studs.
I hear about Ichiba studs being of sub-optimal quality with complaints of them breaking or what not. Not sure if people aren't running hub ring, etc to help reduce load on the studs. I haven't really heard much about the H&R studs being poor quality yet (DRM style).
What do you guys think?
Will be running upwards of 500+hp.
Bryan
Several questions:
Bryan
