St-185 build =Þ sfl
kn0wledge185
Powerslots all around.... Also bought ebc red stuff and Goodridge G-Stop SS Brake Line Kit
kn0wledge185
These just came in.....now I'm just waiting for my brake lines
Overtriped
That looks pretty sweet!! I've go the same set of wheels- the white ones only mine are grey. Also have the same downpipe and midpipe... where did you get the center pipe and muff? Do the new wheels/tires rub?
kn0wledge185
Thanks man.....the exhaust system is from Ebay..... I would of gone with the hks one... But at the time money was pretty low.... so instead out dishing out almost 800 ... I went with the 400 something ...... As for wheels n tires... They don't rub... unless i have the whole family n a trunk full of groceries.... Then they rub..... nothing a fender roller wouldn't solve.
kn0wledge185
Took new pics of my baby.........
kn0wledge185
Also changed the lights out... driver side headlight are the new ones
kn0wledge185
Put my soda blaster together
kn0wledge185
Hey Bryan, What's up man? Yea i started using the soda blaster.......only thing is that the compressor i was using is way too small. ....
uploadfromtaptalk1362837218301.jpg that's the test dummy
this is how much i got done before the compressor needed to pump again. .... I got the blaster from harbor freight........ as for the red stuff I got them from http://www.buybrakes.net/ .......... the power slots from ko racing ........ even tho they were ordered from 12/10/12.... I finally received them on 2/17/13 (rear rotors arrived pretty quick. ...... just the fronts took that long)
kn0wledge185
Finished one caliper. ..... 3 more to go. ....=P
kn0wledge185
Great weekend took all the old brakes off n installed new rotors, brake pads, brakelines with freshly painted calipers & brackets. .......
kn0wledge185
Just when i thought everything was going great. ...... right rear brakeline is sezied up........ I've sprayed it with pb blaster n wd-40 & heated it up...... if anyone has some tips that might help feel free to share...... thanks
kn0wledge185
Both of the rears
kn0wledge185
