I was wanting to get a new Brake Master Cylinder.
I was thinking of just picking up a reman. one at Napa and just reuse my resevoir.
Question:
They list a version for ABS and w/o ABS...is there really a difference to them? Since I removed my ABS unit, I should probably go with the non-ABS I assume?
Anyone else have a recommendation on what master cylinder to go with that hasn't given anyone issues and lasted?
I'm not going with an OEM rebuild kit because te master cylinder I have is not the OEM one, this I know for sure. Therefore, I want to replace it and not have to worry about it down the road. I have two OEM brake boosters, and I'm hoping both or one of them are still good.
After I get this installed, I'll go ahead and make my brake lines with the AGS NiCopp hardware.
I did go to the junkyard today, saw two celicas with no ABS. I picked off the 3-way and p-valve on both of them, with most of the lines (besides the ones going to the rear brakes). I'll be using the lines as a guide for the NiCopp lines.
I'm still debating on using the non-abs p-valve VS my abs unit p-valve VS aftermarket p-valve (wilwood, etc).
Bryan
Question:
Bryan
